Volvo Penta SX-C Replacement Prop?
redriversolar
We caught some rope in the prop and now have a increase in RPMs for same power so I am fairly certain I have spun the prop.
I will get this one fixed but a spare will apparently be handy. I am trying to determine a replacement propeller for my Glastron which is at the lake and struggling to determine the optimal default specifications.
It is a 1995 SSV 195SF with the 5.0FL PHUE motor with Volvo Penta SX-C drive
What would have been the factory propeller it would have come with?
Recommendations?
Thanks
- Dale
Tail_Gunner
Re: Volvo Penta SX-C Replacement Prop?
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
__________________
That was to easy just a cut and paste...:D Try to post as much info as you can...It would be nice if were generic...Just to many varibales
redriversolar
Thanks for the reply tail gunner.
Spun prop symptoms. Higher RPMs than the day before the rope got into a short wrestling match with the prop.
Don't know. The boat is at the lake awaiting my return.
Same as #2
By "wide open" do you mean all the way?
1995 SSV 195SF with the 5.0FL PHUE motor with Volvo Penta SX-C drive,
205hp
1995 Glastron SSV 195 Ski-Fish. 19.5 ft. Not sure about the weight
I would be happy to get this prop fixed or get another identical but alas the boat (and the prop which I forgot to take off before I left her) and I are taking a break from each other for the week while I try to earn the pay that supplies her "go"juice.
Tail_Gunner
So you want ss or alum....120 vs 300...;) and how many people do your boat wiwth on average...water sports or crusing or high speed craziness.
redriversolar
We use it to arrive at our fishing spots as well as tubing and water skiing.
Not uncommon to have 4 adults and 4 kids onboard.
No high speed craziness, I haven't even tried max speed yet.
Tail_Gunner
Are you comfortable with spending 300 or 100..Thats SS or alum...Without going into a long dribble yes SS is generally worth the money...but not everyone sees it that way....SS will out last alum..and let you make little mistakes..like bumping the bottom from time to time..with little damage
redriversolar
Unfortunately here in Winnipeg the Aluminum is already $200 so I will have to avoid the SS.
Tail_Gunner
Tail_Gunner
Hmm Cant find that thing your motor type that is...maybe 215 or 250...Fuel injected should give 250..That is not a duo prop is it....:D
It would be worth your time to go post in the I/O section and see if Don can determine the horsepower..40- 50 hp will make a difference.
redriversolar
Nope, not a duo.
I will post in the other place to seek help on determining HP.
redriversolar
Ok, so if I am look at between 190-220 HP does that help determine the correct prop?
redriversolar
Ok, after some advice here locally I am going to try a 14.5 x 19
