nitrocharger
Thread starter- Joined
- Feb 20, 2007
- 8
I have a '94 VP 5.0Fi (Ford 5.0 EFI) and have been spending the past year trying to troubleshoot a hardstart/idle problem. The engine starts up strong but after it gets past its initial warmup, the idle gets erratic, surges up and down, then eventually sputters out. I replaced the fuel regulator which helped a bit for the starting issue. According to the Seloc manual, I have acceptable, although low, fuel pressure. Engine off I have 38lbs, running I have 32psi.
Normally I would think that the issue could be a vacuum leak but I noticed that with the battery charger on while the engine is running, it runs much better, not perfect, but at least doesn't violently surge. With the charger I get 13.5-14V, without the charger I have 11.7-12.5 from the alternator. I'd love to say its an alternator issue but the fact that the idle still isnt completely smooth and strong has me think otherwise. I also added an IAC too with no improvement.
Any ideas would be greatly appreciated.
Christian
Christian
