wpowell323
- Mar 29, 2009
- 75
I have a Volvo penta 5.0 gxi-e. I am not getting 5 volts to the injectors. One minute the boat will crank and run perfect, when it does there is 5 volts. The next minute it won't and there is like 1 volt. I have switched the ECM and the problem remains the same. I have 12 volts going into the ECm and 12 volts at all other connections. I have not checked to see if I have 5 volts at other sensors, but I plan to tonight. My question is this, is there any sensor or anything I can check that will reduce the voltage to the injectors.
