Volvo penta Gi-G (2006)
rreale
I have been getting 1 beep every 5 seconds.Occurs intermittently after a warm start, it also goes into limp mode. If i put it in neutral and back in gear it stops beeping. Also appears to be running rich, dumps a little fuel out the exhaust after shutdown. Oil level , oil pressure, watet temperature, outdrive level are all normal. When i drove the boat to the mechanic today the issue didnt happen of course. He scanned for codes but didnt find any. Any ideas???
alldodge
Thanks for the Gi-G but need to know what motor?
One beep ever 5 seconds does log a code, it's weird because the ECM is saying there is a problem
For excess fuel would be good to check pressure
Gi 4.3, 5.0 = 29 psi +/- 2
Gi 5.7 = 50-60 psi
Gi 7.4 = 39 psi +/- 3
