sailinphelan
Thread starter- Joined
- Aug 18, 2010
- 1
I need help please. I have a early V/P 280 dp and lost the propellers. I have some later props to go on it, but can't seem to locate a diagram of what spacers or thrust washers to use. I understand there may be a difference in length of the early and later prop shafts, requiring some adapting to take place.
Any help on the subject would be appreciated.
More data: My 280 has 8mm bolt to hold the cone on and manual lift. The stainless props are C6 #3857467 (rear) and another set of aluminum props
B5 85(next 3 questionable)262 5 The aluminum props might be aftermarket, but seem to be about a quarter inch longer on the outer hub part.
They also seem to have a built in thrust washer as part of the inner hub, whereas the stainless ones clearly don't, you can see the rubber hub. On the aluminum ones, the rubber hub is not visible from either end.
Dont' worry about the difference in pitch, this boat only idles around, and right now, I can't even do that. Mainly, if I can figure out how to space them, I can figure out the correct pitch.
Thanks for considering this conundrum.
pj
pj
