DDAADDYY
- May 23, 2004
- 100
So swapping motors this weekend three questions, on an 8.5:1 ratio compression motor I have 135psi as lowest and 145psi highest on warmed up properly done compression test. That seem low? Second This Prestolite IDU7801B 8 F distributor seems OK but can't find much info on the web. What's B.I.D. Electronic Ignition? Have damaged Coil and Prim resistance is 1.7 ohms and Sec. resistance is 6.5 Kohms that seem right? I'm swapping because coil has a hole in it from mech shipping damage. All things point to an MSD Blaster 2 or something like it with 5.1 K ohms sec res and 0.8 ohms prim resistance. Seem blind on the ballast resistor or not requirement on this rare bird of a dist. have fouled plugs and couple burnt wires, knowing I also need carb help, I can do that OK myself, but I'm hoping someone can point me to some answers with my ignition. Inside the only identifier is a paint stamped number "9316" on the module. Sorry should I have done 3 posts? Still man she fires up immediately at 8 degrees BTDC right on the money. Thanks in advance as always guys for any advice.
