I recently purchased my first big project boat; 1987 19'bayliner capri. It has a Volvo Penta Aq131A. After about 6 hours of messing with the timing i got it running. My Concern is under the cylinders there is a brass pipe that looks to be coming off the radiator. This pipe leaks water pretty bad. I was able to get my boat into water and fine tune stuff but then i realized it was leaking water out of this brass pipe. I was wondering if anyone had a similar problem or could tell me how to replace/fix.
My next issue is the dip stick assembly is also disconnect from the engine. it goes in but there is nothing to hold it down. So when it runs the oil is spilling out of it and leaking. Any suggestions? is there anything i can do? There usually is a grommet but I'm not familiar with Volvo motors. Any advice is greatly appreciated, thanks for looking!
Cheers,
Dave
Cheers,
Dave
