San Diego Ron
Thread starter- Joined
- Jan 28, 2023
- 12
My 1999 Monterey 26.2 Cruiser overheats. Pulled boat from water to replace leaking raw water pump believing that was causing overheating. Long story short with muffs on outdrive can not get water up to water pump, when I put garden hose inside boat hooked to hose that connects to inlet of pump the water flows freely out through outdrive inlet holes. Boat has closed cooling and raw water runs directly to water pump, the exit side of pump pushes water through oil cooler and power steering cooler and then to heat exchanger then out to outdrive. When I connect garden hose to exit side of pump water flows freely through everything and out outdrive. Why will it flow out but not in? Thanks for any help.
