volvo penta 7.4 gi runs bad
villain3dusty
I recently bought a 1989 chaparral villain and it wouldn't start unless you sprayed carb cleaner in it. It had some bad wiring so I started splicing them back and I got it to start. Wouldn't rev over 2200rpm without studdering and back firing, so I put in new plug wires, pumped out 50 gallons of bad fuel and cleaned the gas tank,also put in new water separator. no difference. Put in a new ignition module and it ran better but not great. Put it in the water and it just Boggs under a load. Just starts missing and backfiring but every once and a while it'll start to pick up (actually plained ones for a second) so before I start pulling injectors I figured I'd ask you guys. Ive been doing research and it says it has a limp mode where it'll only get 2500 rpm,but wouldn't it be a smothe 2500 and not missing?
tpenfield
Re: volvo penta 7.4 gi runs bad
Welcome to iBoats. . .
I guess you now know why the bot was for sale. . . It sounds like you have done a fair amount with the ignition and wiring. I would check the timing and run a compression test to see if that leads you to any issues.
post back any results and additional info. Is the engine a 1989 as far as you can tell?
Ayuh,.... Welcome Aboard,.... I'd test the fuel pressure 1st, 'n if it's pumpin' at spec, I'm guessin' the injectors probably Need cleanin',....
villain3dusty
Motor seems to be around a 1999. It's got a new high pressure pump. If nothing else I have an intake and carb laying around I can throw on there and for the price I'm definitely not disappointed
bruceb58
Your first post said 1989 and now you say 1999. Can you take a picture of what you are working on and also get us a model number?
villain3dusty
The motor is around a 99 boat is a 89,where can I find the model number?
need pics of the motor.
a serial number would be best.
something is not adding up.
