shockwave2012
Thread starter- Joined
- Jul 12, 2012
- 9
Volvo Penta 5.7- weak/no Spark replaced plug -coil- new batts- distrib reg. ideas?
Here are the engine specs.
Volvo/Penta 5.7GLI PLKDCE
(NUMBERS BELOW )
4110152585-3868702
TRANSOM SX-C1
This is a re-post in hopes of some advice
I gave the boat a tune-up of 2 new battery's a new starter and new plugs 7 months ago.Since it had been sitting and needed it. Ran fine around the canal and full speed.
Then it sat from October to December when I went to start it it cranked for almost a minute, only after letting off the key did it fire up like a late spark kicked after key was turned off. I managed it for the night to show kids the Christmas lights.
2 months later tried to start again and it did the same hard start and this time backfiring while lowered from dock, and filled the engine pistons with water!
Dried everything out for a month, and since i have always noticed the coil pack has always been swollen and rusty, I changed it. I still got a random weak spark. Then no spark at all.
No I have no spark at all.
I have 12 volts going to coil.
I changed the ignition module under the distributor. after reading forums on this being the second option after coil pack.
I am trying to test coil pack to see if the back fire hurt it??
All of the fuses and breakers inside and outside engine bay seem to be fine ( not popped)
Battery's are strong and me and my dad are on the verge of calling a mechanic.
We ordered a manual and it was no help.
(NUMBERS BELOW )
4110152585-3868702
TRANSOM SX-C1
