Volvo Penta 5.0 GSi-J Serpentine belt removal...seeking help
happytrls2you
I've got a 2009 Stingray 205 LR with a 5.0 GSi-j engine..at the front of the motor,I have about 2 inches to work due to the back seats in way...I am trying to see how to replace the belt..not sure where to start dismantling...thanks for any help..
QBhoy
Look up the manual but very easy to do. There is a locking tension system on it.
Ayuh,...... So pull the seat out,.....
Workin' on boats, there's always other stuff that has to be removed to get where ya wanta get too,......
BRICH1260
Put a ratchet and socket on the tensioner pully boat, rotate it, the tension will loosen and you will be able to remove the belt.
