volvo penta 4.3 error MID 187 FMI 9 PSID 200
AlesVolvo
Hello I have error MID 187 FMI 9 PSID 200 on my volvo penta 4.3 year 2011. I change the fuse and relay in box on the top off the angine and is a same. Is ther any other fuse on the angine. best regards ,
alldodge
Welcome
Don't know about another fuse but sometimes there is stay alive power direct from the Bat. If there is stay alive then there will also be a fuse on this wire close to the Bat
AlesVolvo
Hello it can be a problem...before i Have battery 12v/800 a and 140 ah....new one is 12v /1100 a and 110 A is this a problem....
alldodge
No issue with a larger Bat, larger is never an issue
AlesVolvo
Ok what about difrent 140 ah and 110 ah because iff the pcu have more voltage or power doesnt work good/ ok.... the 1000 and 800 is a capacity off battery. I am corect ?
alldodge
No, doubt it
I'm looking at CCA and your current issue has nothing to do with the Bat unless the Bat is near dead and yours are not. The code (to my understanding) is there is no power to that part of the ECM.
ESGWheel
Ensign
AlesVolvo,
12V Lead Acid Batteries (LAB) can be confusing with all the numbers. Any 12V LAB has 6 “cells” each capable of a theoretical maximum voltage of 2.2 volts for a total of 6 x 2.2 = 13.2V. A fully charged battery will actually have about 12.7V. And does not matter if the battery is 140Ah or 110Ah or even 1,000Ah, it will still only be 12.7 fully charged. The Ah (Amperage Hours) are a measure of how long it will last. A 140Ah will last longer than a 110. This is why AllDodge says “larger is never an issue”. It is STILL the same voltage to your PCU. No change. The other larger numbers (800 and 1100) are the Cold Cranking Amps (CCA). The CCA is a measure of how many amps a battery can produce for a 30second period at 0 degrees Fahrenheit, before the voltage drops to an unusable level. Said differently this is a measure of how long you can ‘crank’ (key to the start positions) your car / boat before the voltage drops to low to turn over the starter and/or supply the needed voltage to things like the engine computer. Again, larger is never an issue.
Hope this helps.
AlesVolvo
thank you for the explanation...really nice of you...maybe someone has error instructions off error codes in pdf format. To download... for volvo penta 4.3 gxi year 2011. thank you
