FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
My outdrive will not tilt up. I hear the motor spinning but it doesnt try to come up. The motor is turning at normal speed. New to boating would appreciate any help I can get.
The motor and jackscrew has a built in clutch. It's also possile the reverslock is not UN locking when you are trying to raise the drive. Reach under the drive and manually release the lock, and make sure the drive can be easily lifted, if it will lift easily, then block the drive up slightly and see if the drive will come up with the switch. If it still won't raise with the switch and the motor runs, you my have to add some shim washers to the clutch to strengthen the clutch.
