Volvo penta 270 DP trim/tilt electric motor
imported_Sparky
Recently bought a 1985 Bayliner Ciera with a 260A and I think a 270DP out drive. The Trim/tilt is electrical, it lowers fine but won't raise the out drive without assistant. Do you lubicate the worm screw? I noticed that they seems to be a bit a grease after removing the black box on top and you can see a small hole, on top of the shaft?. Do you think this would help or is the motor to weak? Thanks in advance for any suggestions!
