volvo penta 2002 valve timing
Ayuh,.... Welcome Aboard,.... Volvo used several different motors in 2002,....
Which one ya got,..??
'bout All are cam timed by alignin' the marks on the timin' gears, 'n the keyways in the cam, 'n crank,...
ellisb4
How do you set the camshaft timing on a 2002 penta.
it is a 2002, 2 cylinder diesel, 26.2 cu.
K-2
Are you trying to install the camshaft ? or adjust the valve lash?
Give us the whole back story on what you got going there.
ellisb4
rebuilding a 2 cylinder 2002 volvo penta d motor, putting it back together but have no timing marks or can find any reference's to setting the camshaft timing. The manual says mark the cam and crank when you take it apart but what if you didn't or are replacing the cam?:confused:
K-2
You don't see any small dimple indents on the edge of the crank & camshaft gears. Should look like small center punch marks. I'm just going by what this online manual says. http://www.bluemoment.com/manuals/vo...002_worksh.pdf page 17 . I blew up the pic and I think I can see the small indents on the gears(?)
But then I also read "Not all Volvos have timing marks"
ellisb4
i have that manual but in this section,
7A. Heat the camshaft gear wheel to a temperature of
approx. 150°C (302°F) and use a suitable sleeve to install it .
Check to make sure that the gear wheel "bottoms" on the
camshaft . Install the camshaft and make sure that the
markings on the camshaft gear wheel and on the crankshft
gear wheel coincide
. Put the washer (1) on the hub of
the camshaft gear wheel . Check that all weights are presd
in so that the tabs (2) are inside the washer.
i cant see any marking that might refer to them and can only assume it is referring to the earlier section,
7. Remove the transmission cover: Start by removing the
throttle control cover. Use a suitable type of pliers to
the spring (1) . Then remove the end-nipple (2) and remove
the spring (3) . Remove the oil pump cover and mark the
gear wheels with a colour-pen before removing them .
(When installing the gear wheels, the marked side must be
facing outwards). Remove the bracing pin of the camshaft
using the special tool
p/n
884839. Never remove the
pin by punching it out, this can very well bendbracing the
camshaft . Remove the screws on the transmission cover
and pull it straight outwards.
its very unclear for such an important part. Any other ideas?
thanks Ellis
K-2
No idea. That is VERY vague. Maybe you could use a degree wheel somehow. That's above my head.
ellisb4
thanks, You usually need to set the 1 cylinder to tdc and set the cam intake lobe at 0 lift at the back of the cam but that could vary, i really would like to find someone with a definitive answer. IS THERE ANYBODY OUT THERE?
