Dave Patterson
Thread starter- Joined
- Jul 8, 2009
- 7
I recently bought a 28' steel hull work boat on Lake Superior. It has the 271 C engine. The upper gear box is a 1.61 290A but the lower gear is a DP-A as far as I can tell, based on the Volvo i.d. chart and the shape of the duoprop nose cone. This seems to be mismatched because the 290A specifies using engine oil and the DP-A specifies 90w gear lube. I drained the outdrive and it had gear lube in it. What would be correct refill lubricant. I forgot to mention that the boat was built in 1988 and the outdrive seems to be approx. the same vintage.
Thanks
Thanks
