Volvo DP-A Prop Modified
MDSCP
I'm a new Volvo DP owner and new to this forum so please bear with me.
I have a 1991 570A with a DP-A outdrive on a 24' Albemarle. The props were in rough shape and I was very excited when a bought a rebuilt set of B4s on e-bay for less than $200. I bought the props from a guy in the electrical business who got them as part of the assets of a marine company. Anyway, the props look really good and the #'s match. They both have a tag that says that they were repaired for the DNR.
The forward prop's tag notes a hub and blade repair. However, the forward prop didn't look quite like the old one (which was partly good, because the old set looks mismatched; no ID #s on them) and I finally realized that about 3/4 of an inch of the hub rim has been removed. I can see cut marks through the paint and though they did a neat job, it is definitely not factory.
The result is that when I put them on I end up with a 3/4" gap between the lower unit's anode ring and the prop hub.
My question is: Do I care? The props look great otherwise. Should I be concerned about the gap; will this mess up water flow or be a debris magnet? I'll end up with a gap anyway as the zinc deteriorates. If I care, should I try to make a PVC piece to attach either to the hub to lower unit to fill the gap? If the PVC comes loose will it just get chewed up without hurting anything?
I'm really trying to get my boat ready early this year so I can enjoy the summer. Any knowledgable advice would be greatly appreciated.
