Volvo DP-A prop cone size
sl1234
I need to replace the outer prop on my early Volvo DP-A outdrive and I see there are 2 prop cone kits, 16mm Part# 872614 and 20mm Part# 872549.
What's not clear to me is are the splines on the shaft the same diameter and therefore there is only 1 prop spline size for either of the cone kits?
