volvo carb cable to long
-JR-
Have a solex 44 carb on my Q125a and noticed there is a spring that should be on the bottom side of the linkage of the carb arm where the cable runs threw the spring .
My spring was on the top ,I tried to change it around but the cable is to long to allow that .08 inch on top,as in stated in the manual . how do you make the cable shorter.is there an adjustment closer to the throddle lever.
-JR-
Re: volvo carb cable to long
the Q125 is in a 1984 baylinner
-JR-
Its only 1/2 inch to long .Cable is treaded at carb end ,I was thinging of taking a tap and die set to the cable end and cutting more treads down the rod then cut off that 1/2 inch .
