Volvo aq231/285 Vibration Hard Over
Hook'd
The boat is running great and I'm ticking through the issues. During my sea trial yesterday, my previous concern with intermediate bearings seems alleviated. However, hard over in either direction there is a significant vibration in the wheel. Only occurs at the steepest portion of the turn.
The mechanic who listened to the intermediate for me said it sounds like the ujoints.
I am pulling the upper assembly to swap the bellows and will inspect then. How do I diagnose bad ujoints/parts....other than rust.
Curious on potential cost I started looking online...ouch. I recall a post saying there were alternate sources.
So, how do I diagnose, and best source of parts, procedures, any advice.
Thanks,
bruceb58
Honorary Supreme Mariner
We had what we thought was bad u-joints for the longest time. Ended up being a broken spring on the damper plate.
the first things that come to mind : u-joints, pds bearings, coupler plate
to inspect the u-joints, there should be absolutely zero play between u-joints crosses and yokes, as in none percievable at all while prying with a small pry bar. with the upper off, there should be zero, as in zero play of the PDS shaft.
Hook'd
Where is the coupler plate? Same as damper plate? Where/what are those? I was looking at diagrams without much luck.
Scott, We listened for PDS bearing noise at the ramp, but heard nothing. Probably become more clear when I pull the upper unit to change the bellows. Just want to have the parts on hand.
Thanks,
bruceb58
The damper plate is mounted on the flywheel.
First time I have ever heard it called a coupler plate but it would be the same thing.
agreed, until you pull the upper or the whole drive to check you wont know
also, get a water inlet casting, I would be willing to bet money that yours is corroded (I think they are white metal). I have never found one yet that isnt corroded.
bruceb58
I thought in your other thread you detected bearing noise? If that's the case and you are going to pull the engine, you can carefully inspect the damper at the same time.
Hook'd
Scott, can I find the inlet casting part number in a schematic somewhere?
Bruce, heard something in the first go round, but then had a reputable mechanic listen and say he heard nothing significant. So 2/3 mechanics say no issue....lol.
I figure pulling the upper drive will let me look at all of the outer stuff. Is it possible to remove the outer bearing with just the upper pulled?
I'm gonna make a outdrive stand anyhow, but just curious if it's even necessary to pull the whole drive because that will just lead to....more work.
Anyhow, all good fun and practice for me as this is just one of my 2 boats.
Thanks for everything,
bruceb58
No need to pull the whole drive. Just pull the upper gearcase off.
Hook'd
Bruce, I was looking at the bearing removal instructions included here, and can't see how you would remove the outer bearing without removing the shaft?
bruceb58
I can't comment since I have never replaced the bearings.
