f_inscreenname
Thread starter- Joined
- Aug 23, 2001
- 2,591
Did any of the old Volvos (like the 270 / 280) ever come with a big block? Its winter and just through a rod in the small block. Its project time.
Don said:The problem is that mechanical lockdown can't hold it down and the drive will kick up
Don said:I think you will find you still have that expensive hook, even with the trim.
Don said:As far as the insides of the drives go, they are fine with a big block.
Don said:Knowing you, you will be going thru the transom which will be a lot less heat in the drive and better for performance.
bond-o said:Going Chevy will Cure the Bellhousing Problem,............
Their All the Same................
Sounds like a Fun Project.............![]()
