Volvo 5.7Gsi PEFS twin engine. one with accelaration issues
ds1718
I have a 2000 Four Wins 328 Vista.
Twin volvo 5.7 Gsi PEFS with DP-SM drives
Engine Number 3869059
Fuel Injected Throttle Body.
I bought the boat aftrer it sat on blocks for 6 years in storage.
Had 160 gals of gas on board.
drained 1 tank complete, refilled with fresh fuel.
removed both TBI units, new injectors, and rebuild kits in both.
replaced both fuel pump assemblies (the integrated high/low/tank style)
It ran great for about 4 hours for delivery local, and a few short trips.
Now the port engine starts and runs great.
Idles great.
Runs up to 2200 RPMS great.
Upon accelerating to crusie now does the following.
1. Push throttles forward.
2 Both engines pull great until port reaches about 2200 RPM,
3. Starboard continues fine.
4. Port starts to stuter (like running lean.. sounded like it did on a bad fuel pump)
5. RPM starts to drop, until it reads zero on tach.
6. If I throttle back, it keeps running at idle, and feals great.
7. Tested fuel pump, all good pressures, and new filter.
On last test I got it to pass the stutter.
If i play with the port throttle durring the stutter, pumping it, it will run through the stutter slowly building rpms.
once cruise of 3200 reached, will run great for long haul. so it is just an accelerating issue. Ran it up to a cruise at 4200 RPM, still ran strong! Not starving for fuel once running good.
Could it be map sensor, or a throttle position sensor?
Feals like it is going lean, but by pumping the throttle it goes throught it.
Next time at the boat, I am going to swap TBI units and re test.
Any ideas guys?
Dan
Don S
Re: Volvo 5.7Gsi PEFS twin engine. one with accelaration issues
First thing I would do is check the contents of the fuel filters on the faulty engine. Possibly it's just water or slightly plugged.
ds1718
Already Done.
Drained the TBI too just to make sure.
Still does the same thing.
Very repeatable, every acceleration does it, and I can always get past it with pumping the throttle.
Acts like a carb jetted wrong, but it is a TBI.
And this is a new problem, so I know there is a fault in there somewhere.
dan
Don S
Have you tested the MAP sensor per the OEM manual?
Have you checked for codes? done any troublshooting per the manual?
ds1718
Wow I feel stupid, started swapping throttle bodies, found the vacuum sensor hose unplugged. 50 cent fix with a hose clamp!
Who says boats are expenssive to fix. Just kidding
Crapduster
I like stories with happy endings! :) I am hoping mine ends that way in short order. It is posts like these that give me the push to keep looking and work out all the kinks until reliability is no longer an issue with my boat.
Crappie Duster
