Hi folks,
I pulled a stupid human trick yesterday. Launched the boat and got about 1/2 from the ramp when the alarm went off because the engine was overheating. I left the cap off of the engine flushing tube on the motor, so the raw water pump was sucking air. I put the cap back on and tried to idle the motor to cool it off. I shut it off and on a few times over the course of a 1-2 minutes trying to reset the alarm. I don't remember the exact sequence, but at some point the motor would not start, it would just click.
I got to work on it today and found the cylinders full of water Cranked it over without the plugs to get rid of the water, then sprayed WD-40 into each cylinder and cranked.
I checked the raw water impeller and it was missing a few blades. I pulled the thermostat and plan to replace that also. I pulled the starboard exhaust riser also to check the condition and look for flappers that might have melted. It looks like I don't have flappers in the exhaust on this year motor. The boat is an 05 and I don't know if the previous owner was as anal as me about flushing the motor after each use.
So I have two questions. First, what could have caused the water in the cylinders. I read something about backwash through the exhaust? Is this possible? I'm thinking cracked/warped heads or bad riser/manifolds are out because I had water on both sides of the motor.
Second, what does a bad riser/manifold look like? Mine has some crud but it looks mostly open and clear. I've attached some photos of what they look like.
Any other things I should be looking at? Thanks in advance for any help.
Chris.
Chris.
