Hello and thanks for reading. I have a 2002 Four Winns Vista with VP DP-SM out drive. I'm trying to align my engine to the gimble bearing and have lowered the front mounts as low as they will go. The alignment tool will go in all the way, but not smoothly, and still has heavier marks on top, indicating I need to lower the front of the motor more. When carefully inspecting everything I noticed the aft Starboard motor mount sits higher than the aft port mount. So now I'm guessing that my port side rear mount has let go and is sagging.
My questions are, is it common or likely for the rear motor mount to fail? And will I need to pull the motor to replace the mount, or are there any tricks?
