Hi Guys,
Need a bit of help, this is my first post here so hello and sorry if i'm in the wrong section or anything like that.
I have a 1996 wellcraft 21 excel cuddy powered with a volvo 4.3GL PNCS engine number 4110136898
I am getting a bit confused about what horse power i have and what timing i should set the ignition to.
The dealer i bought the boat from tells me it is 190hp and checking the wellcraft site it says this model had 190hp but the manual i have says a 1996 model engine is only 170hp the engine has vortex on the rockers, i have read that some of the early vortex engines can have vortex on the heads but not be a true vortex engine. i am guessing i have a poor manual which make me a bit worried about using the setting from it to set the timing.
I have the shunt tool and instructions on how to use it it connect to +feed after engine is started.
I have read some great posts here and used many tips and hope someone can help with my questions.
I am in Scotland so i run 95 ron gas.
Thanks for any help you can give Kenny
