Volvo 280 outdrive need help please
Switch707
Ok well i bought this boat 2 months ago had to put allot money into it.I was told the outdrive had been rebuilt but if so they sucked at it.I spent alot on the engine all new pumps all new electronics new prop just allot so took it out first time after running it on land and on dock all seemed well. so cruzzing just fine for 10 minets and sudded as if the prop came off stoped rpm tacked and was making a horible sound in outdride.So brout her back on my 8 hours backup trolling.so ive went threw this site getting all info i can on tear down and its a mess not sure what to do here a bunch picks.The driveline u joins a mess i wont tyo take yolk off and have no idea how mabe fine seems super close to the housing but i need some help.Before i start buying..parts.
https://drive.google.com/file/d/0BwJPz1dCdiRbSkFSR3ZxZ3VtZkE/view?usp=sharing
https://drive.google.com/file/d/0BwJPz1dCdiRbd2ZfM0RGRTdaeGc/view?usp=sharing
https://drive.google.com/file/d/0BwJPz1dCdiRbWnE1anppQlpZNzg/view?usp=sharing
https://drive.google.com/file/d/0Bw...0BwJPz1dCdiRbWllpdFBSZVpFV1E/view?usp=sharing
Switch707
In the pics it should show the drive line u joins are in the back of the boat stuck in it should just pull out right?i looking at new uper boxes that come with the drive shaft u joins and looks as if it just slides in but dont wonna break anything else?
You need to pull the transmission apart to change the u-joints. I highly suggest you download a factory manual, or find a Volvo tech
muc
"Retired" Association of Marine Technicians...
Oh Ya X2
The u-joints should have slid off with the drive. At this point, you should be able to just grab them and slide them off.
Looking at the picture of your input shaft bearings, it looks like this drive might have been run with no or too little lube. If so you might be needing a complete drive.
At the very least a complete teardown and inspection.
Switch707
Thanks guys ya it's a mess I may just buy a hole drive I'll try to see if the u joints will come out as it broke off of drive and seems stuck in good
Switch707
No luck getting ujoints off yet try heat tomorrow also was wondering what drives I can use with the 225 d volvo?since I probably need to change the hole drive just wording..
PatinIdaho
That is a mess!
You should check your PDS bearings also.
The drive you need will have a Gear Ratio of 1:61.1
The lower unit determines the gear ratio
The transmission will interchange from a AQ270 up to a 290-A
If you take the lower unit apart to inspect and all is good with it you only need a different transmission. Around $400 give or take.
There are a few complete units on EBay for around 1K
Here is a manual www.mybayliner.co.uk/boatmad/280285290.pdf
Switch707
PDS BEARING NOT SURE WITCH THOSE ARE BUT THE USER UNIT IS GONE IT'S A MESS SO I GOTO BUY IT I DID GET THE UJOINTS OUT AFTER ALLOT HEAT AND COMALONG THREADS AND SHAFTS ALL GOOD THANK GOD
PatinIdaho
PDS Bearings hold the shaft between the engine and U-Joints
Here is a pic that is similar to your setup..
#65 is a Primary Drive Shaft and supported by 2 bearings. Be sure they are nice and smooth and well greased.
If you buy a Transmission off EBay you also need to shim it to your mid section. Read the manual and it will walk you through it.
Switch707
Ya I read about shims said to pay action to how many except there were none.I'll read up on that.so the bottom and mid all look good surprising but they look real good except who ever had done work to this drive really did not care as there was like tons of silicone between the bottom and intermediate housing. I've cleaned them up.I'll buy the top Trans on ebay saw this one looks like new with new jointshttp://m.ebay.com/itm/Volvo-penta-Outdrive-Upper-Gear-Unit-Box-SP-DP-A-B-C-D-V6-V8-4-270-275-280-290-/152202207990?nav=SEARCH
Will that one work for mine as you said the bottom is fine?I wonna replace all barring while I have it down.if there a list of parts I need you can let me know...aND should I order barring gaskets ect.i from here or any good place I might look.I also wonna take time and really thank you and everyone's help on iboats forum and iboats I could not have got this far without you guys thank you so much got well over 20k in this boat but after this she be a great ocean boat thank you all so much
Roger
Switch707
Ya mine not 1 bolt 2 in 2 out 4 bolt all together just was hoping to hear back b4 I order anything be sure with ebay no returns
Switch707
Ya I thought the Nolte they were talking about was the 4 up front I need one I posted that's bad bottom is good shape thanks
