Greetings, I have a Bayliner with 2 Volvo 260's. Coming out of storage, one engine fires up just fine. The other will not run. It's been awhile since I worked on mechanical ignition system. I pulled the center coil wire to check for spark. There is one, but very weak. I tried a good used coil & still have a weak spark from coil. Connections & wire all look good. If the points or condenser are bad, can that cause a weak spark from the center coil wire?? Maybe I'm going back *** ward in troubleshooting this problem. Thanking you in advance, Larry...
