Re: voltage regulator
The original problem was the battery was getting drained. And volt meter stays 11.5-12v. So i changed the regulator.<br />Now the battery is not getting drained. Volt meter is staying the same. <br />The engine turns on fine at 1st. Took it for a quick spin for about 30min with no problem. Turned the boat off and on again without a problem. Then all the sudden when i try again its just turning and not starting. I check the battery cables and the negative(black)is burning up.
