Re: voltage regulator
Captal, the regulator you need is the only one there is for these motors...it is mounted on the port side of the motor under the manifold, and has a cooling water passage on the back side of it....i beleive this part only avail thru a merc dealer, is expensive and is easily damaged....dirty battery connections/ unhooking the battery running just once will kill them.....you can buy the regulator in a kit with the 3/4" hoses if you still have the old 5/8" intake hose on the engine....
