Hi all. New here so hopefully some of yall can give me some suggestions. I have twin 1982 Johnson 140hp outboards on my boat (J140TLCNB's to be exact) and I am having troubles with my charging system. Long story short, my RH engine is only putting out about 12.4 volts to the battery and my LH engine is putting out about 16.2 volts to the battery. I should mention that my RH engine is supplying 2 batteries to which in addition to the engine, is attached the LH trim and tilt, lighting and bilge pumps, livewells etc. the LH engine has its own battery and is also hooked in to the RH trim and tilt. I know thats wierd! I have changed the rectifiers on both engines. I was just wondering if anyone has any suggestions. I spoke with our local boat repair shop and the mechanic suggested that I remove the regulators from the system altogether. Anyone else done this? How would it affect the battery and battery life since it would be getting unregulated charge from the stators? Many questions I know, Just hoping someone has seen or experienced this before.
Thanks yall!
Steelfire
Thanks yall!
Steelfire
