cfauvel
Thread starter- Joined
- Aug 16, 2005
- 645
1986 225hp Evinrude E225txcda
The regulator is not that old, I'd have to look at the receipts or the date code on the regulator. It is a CDi Electronics version.
I have two AGM batteries 34M (dual purpose) ...one is from 2015 the other is brand new.
Had them both on Battery Tender overnight and both read that they were fully charged....
Started the boat on ear muffs on battery 2 (the brand new one) and within a few seconds it was reading near 16v
Turned off motor and switched to ALL on the battery switch....started motor and within seconds started to read in the 16v.
Turned off motor and switched to battery 1 (the old one) and .started motor and within seconds started to read in the 16v +.
I've had AGMs for years and kept them on trickle charger, as CDI doesn't warrant using the AGM, but if you do, they recommend using dual purpose.
Thoughts? Is the regulator failing ?
