SteuryLover
Thread starter- Joined
- Nov 19, 2008
- 191
If I am trying to correct a slight cavitation problem due to I believe outboard mounting height. Here is a quick question.
What is the difference between a Raker and Viper prop?
Which of the 2 will reduce my cavitation issue and provide more grip is rough seas?
I usually go 15 miles min offshore for fishing grounds, MPG is important to me, I know I want to stick with a 3 blade as I do not want to loose too much RPM. Currently running a 13.25x17 QL alum prop. 18' v hull 1500lbs with motor center console. I am getting approx 5k at WOT with the current setup @34knots with a light load. The boat is used for fishing only and loaded with an additional approx 1065 lbs on top of the boat weight of 1500 lbs including outboard. Thats a total of 2565 lbs while underway with a 1993 Johnson 88SPL. ALL opinions are appreciated. I have done some research and do understand the basics of prop design and sizing. Thanks for everyones help.
