Vibration
RicardoMultibond
New to the forum and need help. I have a 2004 Regal with a 5.0 MPI Alpha Gen 2 I beleive. It vibrated some last year but I did not know it was a problem since all I have owned is outboards. Last weekend it got worst as the weekend progressed.
Really showed up in the turns while trying to throw the kid off the tube. Gimbal bearing? Universal joint? What else should I check. Thanks in advance for the help...
250Gimp
Re: Vibration
I would suspect with it getting worse in turns that it is a U-joint, but the gimbal may have a factor in there to.
One of the experts will chime in to clarify I am sure.
Cheers
RicardoMultibond
Re: Vibration
Cheers
Thats what I think also. Should I run a little bit after greasing?
250Gimp
Re: Vibration
I would pull the drive and physically check the u-joint for play. If there is any play in the joint itself it needs to be rebuilt.
If I remember correctly, you can't grease the u-joint on that drive. The external grease fitting is for the gimbal bearing.
Cheers
RicardoMultibond
Re: Vibration
No way to check the universal joints without pulling the drive? Can I pull the bellows back and check them? Bad thing is I wish I had brought it home from the lake( 2 hours away)last weekend...
cr2k
Re: Vibration
Whole process takes less than an hour. Pull drive (Control box in F) six nuts off pull drive. Inspect/grease U-Joints. New gasket set, Back on. Have gasket set on hand before you start. Grease U-joints and gimbal bearing.
RicardoMultibond
Re: Vibration
Thanks cr2k.....I have a external lube for the lower unit. Will that be a problem and will I have to drawin the lower unit grease?
RicardoMultibond
Re: Vibration
Pulled the drive and both the gimbal bearing and universal joints are good. Guy I bought the boat from been doing the maintenance. So what do I look for now. Any help would be appreciated.
scoflaw
Ensign
Re: Vibration
That rig will never turn as vibration free as an outboard boat would. I had a similar problem, and didn't realize I had a u joint wear issue until I replaced them. The trunions can get grooved, without any noticable play, while twisting by hand.
