dragula65000
- Apr 14, 2004
- 180
I Have an Eclipse GX1000 VHF radio on a center console. I have an antannae made for CC's and is 4'long, mounted on the holding bar around the windshield. I also have a lowrance GPS, and the antannae for it is about a foot or so away on the same bar. I also have an am/fm radio onboard as well. When the GPS is on and the VHF, I get static on the channels and worse when the GPS map is up, but not so bad when only the sonar page is up.
When I transmit with the am/fm radio on, I get feedback thru the speakers, and when the am/fm is off, I get feedback thru the VHF itself while transmitting. I don't think I can transmit at all, but can recieve. I have each component on its one wire, not wired up to each other, but all wired to the same power point. I tried a seperate connection and still the same problem. It worked great before, but now is slowly going south. When the GPS is off, VHF is fine, but distortion is there. I am pretty sure it has to do with the GPS antannae. Any suggestions?
