Looper Piston Question.
vdimenna
Decided to rebuild my looper, after the pin that hold the rings in place fell out.
Has anyone here used wiseco pistons in their engine and would you recommend them over stock replacement?
Thanks
Dhadley
Re: Looper Piston Question.
To my knowledge Wiseco is the only manufacturer that moved the pin away from the finger port holes. We'll assume you're talking about a 1993 & later looper.
Yes, we've run those pistons as manufactured well over 9000 rpm. Use them with confidence.
