VHF Antenna
Gfriedman
How is quality of an antenna measured.
I want to make sure i get something that is good quality. I am going to be using off the shores of mass.
As long as i find something that's 8ft and 6Db gain am in good shape?
Is there any other specs i should be looking at? MHz?
Thanks,
Garrett
DianneB
Re: VHF Antenna
If it is made as "Marine VHF" it will be the right frequency range and handle the full legal power.
As a general rule in antennas, the longer the antenna (and higher the db rating) the better range you will get. 5 feet and over is about as good as it gets.
Gfriedman
Re: VHF Antenna
Perfect, thats what i thought, but the prices just varied so much, i wanted to make sure i had the correct info before pulling the trigger.
turbinedoctor
Re: VHF Antenna
You should be able to find the antenna I mentioned for about $100 or maybe a little less.
Durwood
dingbat
Re: VHF Antenna
The 5102 is a good antenna but is not as well made as some of the others. Personally, I'd go with Shakespeare?s Galaxy Series of antennas since they are a much more robust stick. I have a pair of 5225-XTs on my hardtop and they have well up very well over the past 5 years.
Boatist
Re: VHF Antenna
I agree the Shakespeers 5225-XT is a great antenna and it holds up to very well even in rough water.
There are many antenna that are 8 feet and 6DB gain that just do not work as well.
Some even use a tuned section of coax as a radiator. The small diameter very felexable antenna may work for a while inland but off shore just do not hold up well.
The ones that have a nylon base are good for 2 to 4 years before the nylon base cracks and the antenna goes in the drink. The chrom base is ok for fresh water but if you go offshore get one with a Stainless Steel base.
The ShakesSpears 5225 Galaxy has a solid support and a very good copper radiator.
I have the 5225 XT but 5225 XP is better still.
