Very Sticky throttle
Korean Fiat
Greetings all
Could anyone please assist me in adjusting the throttle control on my 2002 Mercury 50 ELPTO. When I shift from neutral and into forward or reverse and vice versa, it is very stiff. Even when pushing the lever to full throttle, it is somewhat stiff. I have tried with the friction adjustment, no joy.
Cheers
Korean Fiat (Australia)
Triton II
Re: Very Sticky throttle
Sometimes the throttle cable is rigged in a such a way that there are too many tight turns, or one turn that's too tight, or a combination of both problems. I suggest, after the usual lubrication checks (make sure any exposed linkages are lubed and not corrosion bound), that you try tracing the cable's route and if necessary run it in a direct path to the motor. If it's still stiff then you'll need to investigate further, but try the above as it's a no cost option that may work. Good luck, let us know how you go, and welcome to iboats!
TII
Korean Fiat
Hi Triton II
Thanks for the prompt reply. I did check the routing of the cable, and it appears all okay. Im wondering if the problem is in the actual hand controller itself ??
Will have another look, and see again. Otherwise, its off to the mechanic.
Another question about manuals, the rapid share website requires an account ?? yes / no ??
Cheers
Bob's Garage
Before going off to the mechanic, disconnect the engine end of the cable and check the movement. If it is still stiff, disconnect the controller end and check for play. The cable may be bad after 9 years. This would be more likely than the controller being bad.
