very rough idle on 98 FORCE 120
vipersauce
someone posted that it is probably the stator, but to set the low speed jet lower and see what happens. Where is the low speed jets on these carbs. does anyone else have any suggestions? It Idles rough and rises to a high rpm and then all the sudden, it drops to almost a stall, and then starts rising again. It seems like carb adjustments, but I'm not sure what the settings should be on this particular model. thanks for any help. Justin
