I had the boat out today and it doesnt hold a high rpm at wot. This is exactly what happens:
-From idle to wot boat speeds up all the way and has good rpm
-a few seconds later the boat slows down and looses some rpm
-occasionally it will pick up and go and then go back down.
This leads me to believe it is a fuel problem. But this is where it gets more odd. With barely any fuel in the tank, every single time when I would make a right turn while at wot, the boat would increase in speed and rpm. I thought maybe since there was not much fuel it could just be moving around and not getting a constant supply. So I fill up the tank all the way, and then took it back to the water. Now when I make a right turn at wot it would loose rpm and speed. Any ideas on what would cause this?
The engine is a 1995 mercury sportjet 120hp and has good compression and spark.
