Dear All, I have a Mercruiser 5.0 MPI Engine. I did a compression test with the left hand Exhaust Manifold and Riser removed, Sea Water Pump removed, Alternator removed, Thermostat housing removed. I removed these items because they was rusted or sezied and need replacing or unsezied or removal of rust. The Engine has not been started for over 4 years and some items have developed corrosion. (See the attached Photo of the intake manifold under the thermostat housing.
On the left hand side (Port Side) of the engine the results was Cylinder 1=100, Cylinder 2 =0, Cylinder 3 = 0 and Cylinder 4 = 170, this is a very low/bad result I have not tested the right side as yet. Does it make a difference that the hand Exhaust Manifold, Riser, Sea Water Pump, Alternator, Thermostat housing are all removed. As the results are bad, should I just pull of the head and inspect the head gasket and pistons, wall, values etc? Thank you in advance. Rob
