I'm a newbee with a 1992 5.7L Mercruiser with Apha One Gen II (I assume). Engine S/N OD079044, Drive S/N OD647552, Tran S/N OD659499. Bought her mid last summer from exclusive use on NH fresh water lake and she ran great till end of season. It had no maintenance records. I pulled the outdrive (which was a first for me but I've read extensively here, in Merc manual and on the web) and it was VERY difficult to get it off. Took about an hour of tugging, shimeying,and prying. I had it in forward as instructed. The drive and gimble housing were more than a inch seperated before it came completly loose. The gimble looks fine; no rust, turns smoothly and seems tight. U-joints are also tight and seem fine. No evidence of water in bellows. I assume I have an alignment problem but should it be this hard? It may have been many years since it was removed and greased. I saw another post where someone suggested that if the bushings on rear engine mounts are bad that could cause this removal issue. Here is a picture of one and the other is similar. Does this look normal?
<br />I will get an alignment tool but is there a site that gives instuctions on how to align the engine? Thanks for replys. This forum is Great!
