bottomfish
- Oct 13, 2015
- 18
I have a 1995 Johnson J25REOR that after a few minutes of running,moisture builds up on the outside of the intake manifold and carburetor and inside the carburetor horn causing white sludge, eventually stalling out at idle. Starts up after 4 pulls, runs for a minute, spits ,cuts off .Cleaned out fuel tank,new gas same issue. Thinking it could be head gasket, did a compression test which was 100psi + on both cylinders. Any ideas?
