vernatherm replacement on Johnson 40hp 2001
aloha boy
HI: Got to look at my thermostat on my 40 hp johnson , J40VLS1B. It has a vernatherm assembled thermostat, not a one piece as I had hoped. It has a diaphragm, springs cup and vernatherm housing. It seems rusty around the housing, and cup. So do I need to remove the whole assembly to replace the vernatherm that is under the diaphragm? I hope not to have to remove the cylinder head to remove the housing. Or can I just replace the vernatherm? I know the diaphragm is old but not cracked. Is the housing and cup easy to remove?
Thanks for your expertise help.
oldboat1
Sounds like you have it apart. Clean it all up with fresh water and detergent, then check for corrosion damage -- better to replace than overheat. You should be able to test the vernatherm to see if its operating. Consider just replacing it, maybe keeping it as a backup if it's been a while since the last replacement.
aloha boy
No I don't have it apart, trying to figure out how to get the verrnatherm out without taking the cup. diaphragm, etc. out if that's possible. I only have the new vernatherm and not the whole assembly. I should replace the complete assembly as it has some rust, but it looks tough to get out. What is your suggestion?
Thank you.
oldboat1
Well, think your choice is either to leave it alone or open the assembly. On leaving it alone -- Do you have temperature issues? An infrared tester is a good investment (check surface temp at the top of the head. Expect 130-140F or thereabouts.) If no current issues, your option is to keep an eye on it, and replace as needed -- but before you get an overheat condition. That's the trick.
Check a parts diagram to see what the assembly looks like, if you haven't done that already: http://epc.brp.com/SiteMods/BRP_Public/BRP_Public_Login.aspx?ReturnUrl=/Index.aspx Plug in the info on your model, and find the cylinder/crankcase section. There should be a couple of springs in there, a gasket for the cover, a washer, diaphragm, cup. If you decide to open it up, I would use some ATF or other lube on the cover bolts beforehand, and let them soak a little. Salt corrosion will make things brittle. Once open and apart, do the cleaning and examination. Replace anything that looks doubtful. If you have a replacement sensor/v.therm, I would just replace the old one and keep it as a spare (check it to see that it's still operating).
Sooo.... your call.
aloha boy
Thanks oldboat 1 very helpful suggestions. Will proceed when I have time. Do I need a puller to remove the housing? I have a infrared gun, cheap so don't know how accurate but will test head temp. next time I run it. Will order the other parts as soon as I can confirm the correct parts for my engine which is not listed in most parts catalog from on line parts dealers.
