Vent plug
azmick
Magnet on end of top vent plug broke off while i was replacing plug after changing gear lube and is now in gear case. Tried flushing it out by pumping oil through top vent hole. Will it damage lower unit? Can't get it out. 2005 johnson 150 plsoe
Do not run the motor untill that piece is in your hands !-----------May have to take lower unit apart to find it.--------Model # is ?
Remove lower unit.-----Remove waterpump.-----Remove bearing housing under the pump.------See if you can spot that piece.
azmick
Sounds easy enough raceone thanks, just changed water pump, hopefully i can save gasket
joeanna
been there done that:facepalm: on a motorcycle....i removed the battery and starter instantly. after removing the last parts and engine from the frame, I found the small part under the kickstand.....better safe then sorry..good luck!
azmick
Hey racerone, i was told maybe i could pull shift rod cover. Would that be easier then water pump and bearing cover under water pump?
