My boat is an 18.5 foot Cobalt with a 205 hp 4.3L Mercruiser I/O. The dry weight is about 2,850 pounds. I currently use a 5-blade Ron Hill prop that is better for water sports than my 3-blade. RPMs at WOT for the 5-blade are around 4,700, which is near the top of the 4,400-4,800 range for my engine. While this seems to be the right prop, I wish that the hole shot was better, particularly with more than 2 people in the boat. I have read on this forum that vent holes help the hole shot, but more so for an outboard motor than an I/O. If that is true, would it still make sense to try the vent holes on my 5-blade prop. If so, should the holes be smaller because there would be five of them instead of three? If so, what would be the correct diameter of the holes? Thanks for you help.
