Mjohnpilot
Thread starter- Joined
- Apr 6, 2015
- 2
As stated in item 1, the boat has an extremely poor hole shot. I've been boating since 1969, owned 2 other boats, 18' Glastron Tri-Hull and a 24' Pontoon boat. The only time I've seen as bad a hole shot as the Gambler has is when I was trying to pull a bunch of skiiers with the Glastron. Once the Gambler finally starts to plane out and the speed picks up it goes like a stripped ***** ape! With about 450 lbs of driver and passenger we have seen close to 70 MPH GPS at WOT. I am considering drilling, or having someone drill, vent holes in the hub but not sure how to locate the holes or how big to drill them.
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct. Very poor hole shot
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Suzuki Stainless Steel
3) Current prop diameter and pitch (required). 14.25 x 24
4) Wide open throttle RPM and speed with an average load (very helpful) 5800 - 6100
5) Engine/drive make, model, year, and HP Suzuki DT175 1989 175HP
6) Boat make model, year, length and weight Gambler 1989 18' 3" not sure of weight
