Velvet Drive Transmission Noise
seapack
Has anyone had experience with Velvet Drive Transmissions? I recently rebuilt my 350 Mercruisers. When reinstalled, the starboard transmission clunks and rattles when it goes into gear. It did not do this before I took it out. Could it be an alignment issue? It looks good. They are early 1970 version 2.57:1. Any help is appreciated.
tommays
Re: Velvet Drive Transmission Noise
the only easy thing i have seen is the spring plate on the flywheel can be lose <br /><br /> we had the springs fail from rust a lot of noise<br /><br /><br />tommays
Capt Ken
Those transmissions will be the first to tell you if your engine isn't running smoothly. If it rattles and knocks at idle, but quiets down if you bump the rpms up, then your engine isn't idling smoothly. Try moving your idle up and see if it quiets down. What is happening is the planetary gears are shaking and rattling.
seapack
Thanks for the input. It does settle down when I raise the RPM's. It is still noisy going in and out of gear.
Rainmaker
That really sounds like a destroyed damper/coupler on the flywheel. If the springs are totally shot it will clunk loudly when put into gear. Then rough idle or power imbalance between the two engines will cause a rattling sound. The plates rarely fail altogether.
