vapor lock
waterzipper
I did a search on vapor lock and didn't see any solutions. I have a 1988 mercury 45 horsepower "nifty fifty". I've had it for four years. It has never run right. I've had three different mechanics spend hours on it and it still doesn't run. This is the problem: When it's cold it starts. When I get it out running it is fine for 10 or 15 minutes and then it starts to decrease in speed, even when I have the throttle all the way down. Sometimes it stops completely and then I can't start it again. I've tried new batteries and new fuel lines. When I first got it the mechanic removed the fuel injection resevoir and now I mix the oil with the fuel. Could this be the problem.<br /><br />Does anyone know how to fix this?
Solittle
Re: vapor lock
Welcome Water - What you describe is a motor getting hot. When was the last time you changed the water pump & Tstats?
waterzipper
Re: vapor lock
Hey Solittle,<br />Thanks for the suggestion. I'll check out waterpump. What are TStats?
heyttown
Re: vapor lock
Tstat is another word for thermostat, similar to whats in the car, temp builds up as the motor get running, at a certain temp, it opens letting cooler water flow through the motor.
