bengaltiger14
Thread starter- Joined
- May 14, 2012
- 48
Hello all,
I have a 2005 Sea Ray with a Mercruiser 5.0L MPI engine. Cold starts off the trailer perfectly every time. I shut the engine off after running for a little while, getting the engine up to operating temperature. I sit for a half hour up to 1.5 hours and try to crank up but it will not start. It turns over just fine but will not start unless I rev the engine up while cranking. Also, this happened last week after just running the boat at idle for 5 minutes. I don't believe it ever reached operating temperature. I changed the engine mounted fuel/water separating filter and saw no signs of water. Checked the fuel pressure and it was at 40-43 psi.
Now, yesterday, the boat cranked just fine off the trailer but then shut off when trying to put it in forward. This has not happened before. It would not crank back up at all unless I revved the engine. I had to rev the engine (at low rpms) for about 10-12 seconds in order to keep it running.
I did notice that when cranking, some type of alarm goes off briefly (approx. 2 seconds). It is not the low oil pressure alarm that goes off when turning the key. It happens when turning the key to start the engine.
