Re: valvoline conventional or castrol gtx?
<br /><br />Maybe a better exaggeration would have been,Acme oil. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Not trying to start anything here ,but you mentioned two oils that you attributed to problems in a test result,and then say that you agree that most oils are good oils and the filter is what is most important.Do you then think that some of your earlier tests were a result of a cheap filter or cheap oil?Or both?<br /><br />BTW ,my earlier mention of Wolfs Head oil was an exaggerated statement to make a point that even a superior grade of oil is inferior if dirty to a lesser grade.Don't think I've actually even seen Wolfs Head oil but rather heard the mention of it in a comical line by Belushi in the movie "Neighbors" , when he gave his car to Vic,played by Dan Akroyd.He said, "She'll need an oil change in about 1000 miles.I use Wolfs Head Golden 30.It'll never let you down,buddy."Originally posted by SS MAYFLOAT:<br /> <br />I will say this, air cooled engines that had Valvoline & Wolfs Head run through them seemed to have the worst build up of parafene in them. They also showed excessive wear on the bearings, valve guides, and cam followers.<br /><br />Like Lubedude mentioned earlier, some oils are good in some engines while not being good for others.<br /><br />My best suggestion in not necessarily the quality of the oil, but the quality of the oil filter. Cheap oil filters like FRAM have killed many engines. Lubedude is right that most oils are good oils, but install a good filter if you want to prolong the life of your engine.
